PowerSkin has revealed a new external battery that is one’s of the world’s first Apple-certified iPhone 5 external charging solutions. The PowerSkin Pop’n attaches to your iPhone 5 by sticking to existing cases and it’s available for purchase now for USD$79.99.
The PowerSkin Pop’n battery charger offers a strong boost of battery power. It quickly and easily attaches to your smartphone or onto existing cases. It’s slim and secure, and even makes a POP sound when you take it off your phone when its done recharging your iPhone.
It comes in two versions. The first version of the case has an iPhone 5 Lightning connectors, while the other has a micro USB charger for different Android devices and other smartphones.
The case is 10mm thick and measures 5 x 2.2 x 0.41 inches. It sticks to the back of your iPhone or case with little suction cups . The battery is a 2000 mAh battery that promises to extend power up to 70%.
Right now you can choose between a black or white case, but red and pink options are expected to arrive soon.
If your battery is constantly dying on you before your day is done, this might be a great solution. If you’re willing to shell out $79.99 then this could be just what you’re looking for these days. You can check out more details on the PowerSkin website and order yours today.
